NotoriusCSR
whats the best way to get rid of understeer? ive got tokico/eibachs and polybushings on right now.
I have the 24/26 setup on my '94 ATX now, and with the SFC's I'm pretty happy with it compared to stock, although I would still like a little less understeer and may try a 22mm FSB from a SLO wagon (if I can find one) and see what that does.xssho1:
like a 24mm/26mm or 24mm/28mm combo?
I'd recommend that combo, yes. I'm real happy with it, and it will work well for those long sweeping turns.NotoriusCSR:
well in colorado the roads are either straight, or long and have sweeping curves in them, tight corners are usually only found in peoples driveways. so ud recommend 24/28s?
Yes, definitely.and will adding SFCs help at all?
So then why didn't my 24/23 combo handle better than my 24/28? I lost a LOT of understeer when I put in a bigger rear bar. The understeer is caused by having a front bar that is too stiff, causing the inside wheel to spin under acceleration and the car to push. In non-acceleration situations, the tires don't have enough grip to keep the stiff front end planted in comparison to the lighter rear bar. At least that's how it was explained to me...SHODWN:
21/26 ? John your crazy. Understeer is caused in our cars but a thin front swaybar and a fatter back one. your front end is twisting and the back is working 4 times as hard trying to keep it flat. Thus this causes your pushing in cornners
and when it catches with a stiff back end will pick a tire off the ground (like your pic shows) im sorry but 4 tires on the ground will always be better then 3. take the 21 and use it to hang parts from when your painting stuff.
Kirk, this is exactly right, the front twists enough to keep both wheels planted. The back will unload one wheel if bar/spring combo is stiff enough, leading to an oversteer condition. A FWD car, if taken to extremes will have a snap condition, very dangerous at high speed on the street.SHODWN:
21/26 ? John your crazy. Understeer is caused in our cars but a thin front swaybar and a fatter back one. your front end is twisting and the back is working 4 times as hard trying to keep it flat. .
