underdrive p/s w/p belt broken
Frankiek3
Man this sucks.
I wanted a better parking spot last night so i drove my car about 100 yards closer to my place. It couldn't have been that easy, my p/s, water pump belt broke, I don’t know if it was from the cold weather or what.
It made some smoke and i thought it might have started on fire, but luckily it did not. Seems it only is on one part of the belt so it was cause by the crank pulley not griping it.
Anyone know the part # for the underdrive p/s w/p belt?
HighSpeed
Low Drag
Chicago, IL
Here are the two belts that you need, if this was what you wanted to know:
PS-WP, Gates K040500, RockAuto.com $13.29
A/C-Alt, Gates K060445, RockAuto.com $14.44
This is also a good time to replace the leaky cam seal on your sig, you may want to replace the CID since the oil leak might have ruined it or will ruin in.
Camshaft oil seals - 3 seals required
Fel-Pro TCS45870 - set of three, RockAuto.com $14.63
Cylinder Identification Sensor(Camshaft Position Sensor) -
Wells F134, AutoZone.com $27.99
:cool:
