two to many cars. need some help
kurtis adum
Driver
michigan
well i have 2 94's.
a 3.2 with a horrible body on it but the motor is really strong. Tranny shifts good but could be better. Its pretty rusted out and the suspension is hit on it also.
a 3.0 with awesome paint, for the most part. it lowered and all that, a lot nicer car, but after the weekend i had, i need a new tranny, again.
i figured hey i really only want one, but am goin to need some help doing it. If can get the help and find another tranny i would like to do the 3.2 swap into the mtx. i couuld have all the funds and everything that is needed to do the job in just about a month or so. If this doesnt work out than my only other option is to drop out the game. If any body can help let me know, cause in that case i will start collecting everything i need or looking for new homes for these cars. thanks
kurt
1slickRED89
Guest
Toledo Ohio
i'm moving the end of this month but would be willing to lend a hand, if i can. I've never done a 3.2 swap though, so my expertise might not be too helpful. shoot me an email with you schedule, [email protected]
shoteen95
isn't a teen :D
Dearborn Heights, MI
i'm as dumb as a doorknob, but i'd still come over and lend a hand so long as you just make me do the easier ***** work... :biggrin:
kurtis adum
Driver
michigan
sounds good. its hard to let them go, and i think i already found another trans. if im going to put the 3.2 in the mtx car, what am i goin to need? which wiring harness and all that?? i did a few seaches but am still a lil confused thanks and hopefully this will happen
kurt
Speedy_91_SHO
Toledo, OH
complete drop in. The only thing you have to change is the intake. Also, many believe that swappingthe heads off the 3.0 and putting them on the 3.2 (really can get away with only swapping the intake cams). Everything else is oretty much the same. Set the 3.2 on the 3.0 subframe and mounts and I believe that is it/
Bizzy
When doing a 3.2 swap, you have the choice of keeping the 3.2 heads. If you keep the 3.2 heads you'll have to do some changes for the alternator and a few other things to make it work. I thought it best when doing mine to use 3.0 heads out of a 95 (Jezebel's to be specific for those of you who remember her). My cams were being swapped so the 3.0 cams were of no interest to me.
Please, please, please do not forget.....if you use 3.0 heads on your 3.2 block that you must buy a new 3.2 head gasket set.
