Tweecer rt display question
Mike Kelly
Middleburg, Florida
On the dashboard display, The guages do not spring to life. In the bottom right corner of the display the small boxes have numbers showing and changing all others are not. I tried going thru the steps many times to see if i'm missing a step, but no luck.
It's probaly something simple, I just don't have enough knowledge yet.
Thanks Mike Kelly
strings1732
RMTE-TRBO-SHO
colorado
What kind of computer are you using? it's possible that your computer is just to slow. Mine is and does close to the same thing...
Mike Kelly
Middleburg, Florida
repaired & working
Thanks for the help. :thumb: The J3 port needed more cleaning.
Thanks again. Mike
"please make sure the connection with the J3 port on the EEC is clean, and that you followed the steps above correctly."
