Turn Singals/Flashers Don't Work?
Spring Hill, FL
Its probably a basic question, but I gotta ask, what could do this? My dad says it probably a relay, and that sounds right, but just incase its not, might as well ask about it, just for reference. Thanks :wave:
rangerj
Brunswick, Ohio
Your dad is most likely right. There is a "flasher" that is used for the turn signals and hazard warning. It is a relay that cycles on and off so that your turn signal lights "flash" on and off. It is usually under the dash on the driver's side or in with the fuses, also on the drivers side.
If your turn signal light just lights up, but does not "blink", or blinks very rapidly, these are the tell-tale signs of a failed turn signal flasher.
rangerj
