Turbo SHO is down... Pictures! updated october 25th!
SHODWN
Mother Threasa
Spencer,Ma usa
Well to answer the two of you:
Today, without dumping out im 205lbs and at 6 feet tall im a 27.8 on the BMI index
BMI Categories:
Underweight = <18.5
Normal weight = 18.5-24.9
Overweight = 25-29.9
Obesity = BMI of 30 or greater
Bob G you looked knocked up the other day so you sure as F cant talk! :laugh_ti:
As for you John, you couldnt get your enourmous head under the dash anyway so..... :naughty:
Clean it up or Ill have James smack you guys in the mouth with the brain!
Here check yourselves out! http://www.nhlbisupport.com/bmi/
zak
east of Hartford
Lets see if i can explain this.
I had to bend mine forward more as I have bigger arms
I take a break here because its dificult with your arms in the position. So I then adust
there is a blue saft that moves
Hold that in place and push the down and lift this peice up, now pull
see if thats where you need it, if not adjust it some more.
be carefull and dont touch it!
then find the theeth of the quad.. its all up as high as you can see, its there.
6. this is the toughest part, you are on your kneesout outside the car, your left arm is stuffed in
This sounds harder then it really is, the first few times you will mess it up, but then you get the hang of it and its pretty simple to ajdust if you need more.. Tony is a genius!! for doing this . . .
You really have to look good at this before you attempt it... your working mostly blind, and in a position that a 6' 200lb guy that is anything but natural.
:evilgrin: Id like to see Murph try this (hes like the size of Hulk Hogan)
Ahem. Biz demands a certain level of decorum on this list, you ***** fat bast@%# :salute:
And yes, I have tried to view the underdash clutch quadrant and find I can not (sigh).:rofl:
zak
texantony
Arlington, texas
zak
Hahahahahaha!!!!!!!!!!!!!:lol:
You beat me to this.
btw: I represent the lolipop kids:hyper:
nik97
Mile high
Ok I'm thinking and it seems this mod is more for a clutch that will not fully disengage or drags... correct?
My clutch will disengage at the very slightest little tap of the pedal; like it has no free play or is simply worn out.
... Going to stick my head under the dash...
Westerly, RI
BMI Categories:
Underweight = <18.5
27.7. I'm retaining water. :p
SHO_DOODmorrris
Owner & Fanatic
Alberta
Okay boys enough withe the BMI shit...
back on track, ive just recently had that drive ive been waiting for to fix my car... its in the garage as we speak and i need to take off about 4 more bolts and the tranny is out... pics are coming soon!
SHO_DOODmorrris
Owner & Fanatic
Alberta
nuff said... hopefully cluchmasters will warrentee it... less than 5000Km on it and NEVER launched...
