kzoosho said:
they say u can run less boost get the same power but gain power in the low end thats all i was wondering
Down and dirty answer is yes. The more HP your engine has NA (generally speaking), the more it will make with a given amount of air. So, a 200whp NA SHO will generally make more power with a certain amount of boost than a FI SHO that started out as a 180whp NA car (keep in mind that boost is simply a measure of restriction not neccessarily a measure of airflow, eg; a head/cam SHO will flow more air at a given rpm, and given boost pressure, than a stock head/cam SHO). Make sense? So yes, more compression (to a point) will make more power, assuming all other variables are the same.
As far as making more TQ at low rpms, it is a moot point. For one, it depends largely on compressor selection, exhaust design, the modifications done to the NA engine, etc, etc. Besides, with a properly matched compressor, you will have all the TQ you need, whatever CR you choose. In the end, I would never recommend someone looking to make MORE FI power to do so via running a higher CR. If ultimate power (HP and TQ) is your goal, forged pistons are a good idea. FWIW, Josh @ SHOnut makes incredible amounts of power with his stock block (including bore and pistons last I heard) SHO. Keep in mind he has an air/water aftercooler and is a Tweecer genuis. And he has still blown a few pistons up from what I have heard. For the trouble of replacing broken pistons, and the possiblity of further damage, I suggest spend a few hundred dollars on some forged slugs with a slighty lower CR. You will then noy be limited on the amount of boost you run (to a point, assuming you have the other mods you will need).
