Tunes and what they do with octane and ethanol content
Hi Tek
Texas
I'm trying to understand spark timing at WOT on the EcoBoost to be able to evaluate a calibration change (AKA "tune") when I get one. I'm also interested in figuring out how much octane and ethanol the factory tune can make use of. I used to go a little beyond E10 on my CTS-V and STS-V with ethanol to lean out the mixture a touch and make more power through the combination of more alcohol than the factory setup compensates for, plus the extra blend octane that ethanol provides.
On my data logger, it looks like starting from a dead stop, the EcoBoost starts out a WOT run under vacuum running fairly normally (without much timing advance under load) as if it were a NA engine, not taking advantage of premium octane at all while still under vacuum.
As it nears the crossover from vacuum to boost, the car pulls timing way back until it gets into boost territory.
Once in positive boost, the ECU runs timing aggressively up to 20+ while at WOT.
I'm going to making a few runss with an almost empty tank and a warm engine on my normal 93 octane. Then I plan to fill it on 87, burn the 93 out of the lines, then make the same runs on mostly 87 and compare results under the similar conditions.
Hi Tek
Texas
What's your AF gage show? How about FI duty cycle?
Hey Paul - been a long time!
I have the the Kiwi WiFi OBD II connection and REV iTouch/iPhone software. I don't see a log setting for A/F but it has choices for a number of intake readings, and fuel trim and other fuel settings. I might be able to find the right 2. Wish I had a wide band 02 sensor! I have not found FI duty cycle yet but I will dig a bit through the fuel readings options.
-Jim
crystizel
