Tubular Subframe connectors
WSC-SHO
SHO Groupie
Nebraska
So this idea begins late at night, as most of mine do... :nut:
Has anyone ever made sub frame connectors out of heavy wall tube? Something like Sch 40? I was thinking if you sectioned it in half where it sat on the front "rails" and where is sat on the rear strut box, it would be as strong if not stronger than the square tube ones currently in use. You could also weld a brace/gusset in where it bends to further prevent twisting. I'm thinking I'm going to fab a set up and wanted to see what the general consensus was..
:wave:
HotRodKid
mmmmm ... turbo
Western NY
pound for pound, your better off running double small tubes then running one larger thicker tube. Also helps with ground clearance.
Ive played this game already. rolling tube was part of my duties at the fab shop.
WSC-SHO
SHO Groupie
Nebraska
Sectioned 1.5" tube would be 3/4 tall where it mounts to the "frame" That's around what people use now with the 1x2 bars. Also, tube is inherently stronger than square, although I'm not sure if torsionally this is true..
firebat45
Edmonton
Torsionally (round) tube is stronger than (square) tube. But you're cutting the tube in half, which will drastically reduce it's strength. If you take a drinking straw and bend it, it's got a small amount of force resisting you, but if you take a drinking straw that's been split lengthwise, it will have almost no strength at all.
Half a tube is a lot less metal in the vertical plane than double 1x1 tubing. That's where the strength in the SFCs is, and that's why double 1x1 is marginally better than a 1x2 laid flat.
WSC-SHO
SHO Groupie
Nebraska
I won't be cutting the whole tube in half, just sectioning it where it welds to the "frame" rails up front and the strut boxes in back.. I'll probably reinforce it with some flat steel as well, something like this..
Off Road SHO
Moderator
Then you're good to go, except you need to weld your round tube to the semi-flat frame rails. Of course you could always weld flat stock gussets all along the frame rails and end up with a lot of rounded bottom square tube, but that sure seems like a lot more work.
Tom
HotRodKid
mmmmm ... turbo
Western NY
If your that worried about making these incredibly strong, you need to run another tube down the rocker panel lip with diagonal braces to the SFC's, and the tubes cant just be connected at the front and rear, the have to be skip welded to the sheet metal their entire length
think about it, everything else on a unibody car is welded every inch, your SFC's should be to
whiteguy3
Scott MacIntire
Silver Spring, MD
I did it. I custom made my subframe connectors for about $45. They were a sinch and were made out of square tubing. I also made a custom cross-member bar connecting the two subframe connectors right before the junction boxes.
WSC-SHO
SHO Groupie
Nebraska
Do you have any pictures?
And HRK, what do you mean by running another tube? And I was planning on stitch welding them their length down the rails in one to two inch segments to avoid warping.
LJRuddy
Pop lock n drop
Poaceae fields
If/when you go to put your connectors on, make sure you have the car off the ground and on jack stands. You want the connectors to be welded to the body without the load on it so that when the car is put back on the ground, the connectors are actually doing something other than being extra added weight.
WSC-SHO
SHO Groupie
Nebraska
I understood you wanted to have no weight on the cars wheels, so that that chassis was flexed upward so that the connectors would be pulled tight against the downward force of the body once it was lowered back to the ground.
LJRuddy
Pop lock n drop
Poaceae fields
Thats exactly what I was trying to say... I seem to lose my thought when I attempt to type something out. :nut:
HotRodKid
mmmmm ... turbo
Western NY
like this:
and dont bother stitching them solid, run a 1" bead's with 2-3" spaces between. Even our spreader beam at the fab shop was skip welded like that, and we hung 10 tons of steel from it no problem.
WSC-SHO
SHO Groupie
Nebraska
Are the outside tubes in that system welded to anything or just hanging out there?
DJSHO91
Durham, NC
like this:
Sweet set-up! My 1st thoughts are "It's a bit over-engineered for a street car", but definitely give you top marks for ingenuity. How much weight does the whole set-up ad? :salute:
HotRodKid
mmmmm ... turbo
Western NY
Those are just pics i pulled of the net, i didn't make them.
if you made something similar out of 1.5" x 1.5" x 3/16" it would prob work out to 120 lb, maybe a bit more ... and thats probably overkill on material thickness.
WSC-SHO
SHO Groupie
Nebraska
schedule 40 works out to being just slightly over 1/8 inch.. 3/16 would be overkill
crystizel
