Trunk Seal
Blast7
Rochester, NY
I have a trunk seal that I purchased a while ago but I am not sure if it is the correct one for a Gen 1. Will I be able to tell if I measure it. I want to check before I go ahead and put it on. Also, what kind of sealant should I use for the trunk seal?
jthomas68
Area 51
I think you may be able to tell by the shape.Lay it out flat on the ground.The Gen I is a rectangle,the Gen II will have more of a "dip" in it on the long side.If it`s new,i have a part # you could check it against.
Bizzy
lb-sho:
use gorilla snot for weatherstrip adhesive
its the best
Not on my SHO! ...no how ..no way! :p wink
Clear silicon sealant works well. It stays clear and flexible. Just a small bead will work well.
DHMag
Free At Last
InCahoots, Texas
Blast7:
3M Weatherstripping Adhesive. a little goes a long way. 5 ounce tube at AutoZone for like 3 dollas. its what just about all auto manufacturers use for the weatherstripping.
