The quickest way to find out if that is your problem would be to connect the hose back up and go for a test drive.
If it is a vacuum line, it would cause a vacuum leak that will definately affect drivability.
If that is a line that controls your secondaries, you will find that you've been running with then open all the time. Such a condition will greatly affect your engines performance up to around 4K, the the engine will take off like it is supposed to (you will have lost a great deal of low end power).
The vacuum hose routing on the rear of the intake should be something like this:
Small hose (about 2-3") from port on intake to small black cylinder clipped to bracket on intake. (Called the Secondary Accumulator or Vacuum Reservoir)
Small black hose from the secondary accumulator to an electrically operated valve (Idle or Intake Air Control Valve, IAC Valve). This valve should also have a 2-wire electrical connector on it.
Small black or gray hose from the IAC valve is routed under the intake manifold to a tee connector located below the ISC/IAB valve. Each branch of the tee goes to one of the IAC motors (vacuum motors).
There is a diagram of the part of the circuit located in this post:
http://www.shoforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=17;t=002502#000000
Be advised that the artist used the designation IAC (Idle Air Control) for the ISC/IAB valve Idle Speed Control/Idle Air Bypass) in the drawing.
On the other hand, after posting, I noticed you are in California.
CA MTXs also included EGR which increases the complexity of the hose arrangement. yours would have an additional vacuum line from somewhere on the vacuum manifold or intake manifold to the EGR vlave solenoid and a line from the solenoid to the EGR valve proper. A second line (not vacuum, but high temp rubber) runs from the EGR tube to the PFE sensor.
There should be a vacuum schematic on the plastic plate behind the radiator. See if yours is still there and is legible.
Hopefully, these descriptions will give you enough info to identify the loose hose and connect it back to where it belongs. Let us know of the outcome. Feel free to ask additional questions if needed.
Steve
<small>[ February 15, 2003, 08:29 AM: Message edited by: projectSHO89 ]</small>
