Off Road SHO
Moderator
Hey guys, I'm doing my first valve shim job and I'm having trouble with rotating the cams to get the final shims out. Something is keeping the cam from rotating more than about 60 degrees. This of course keeps the lobes on top of the shims on the last two of each bank. I think the lobe might be hitting the "bucket" of one that allready has the shim removed.
I was hoping to remove all the shims at once, measure them and then figure out which new shims to buy. Is that not the way? Or do you buy a bunch of shims first, not knowing what you need?
I am using Scott's nice little worksheet for the number crunching. Any help would be appreciated. Thanks
Tom
BTW This procedure is a real PITA, and my engine is OUT of the car on an engine stand!
Tom
