TAM
Just tried to swap out my PCM and I ran into problems trying to remove the white plastic clip holding the PCM in place. Has a small screw at the top I just couldn't get ahold of with anything I had tool-wise.
Seem to need a small maybe 8mm metric box wrench to loosen it. Sound about right? How does the clip come off? Pull it out and down, or what? Will get some small metrics and try again - just wondering how to remove the white plastic clip once I get small bolt at top loosened? Thanks!
