Tried to remove the air horn..
stevemainian
Virginia Beach, VA
but couldnt find it.
I poped the hood, unclipped the air box, and removed the air filter, reach my hand down the hole in the air box... and felt the tube that goes down from the box to the fender... So i laid down, put my head under the car and looked for it... I cant find this darn horn.. Where is it!!?!?!?!?! Pics would be appreciated. Does it sit inside the tube going from the box to the fender well?
revhardSHO
Seattle, WA
It IS the tube that goes from the box to the fender well. LOL
Remove the outer airbox too.
stevemainian
Virginia Beach, VA
oppsss... How does that bitch come out? I wa spushing thinking that was it, and nothing.. Maybe I gotta put some asss into it. And what exactly do you mean by outer airbox?
ckinart
Mississauga, Ontario
Have a look here for some info on removing the silencer cone. I found it easiest to just remove the front left (driver's side) turn signal and reach in and pull the silencer cone out of the outer airbox. If you remove the forward side of the driver's side splash guard inside the front wheel well, you'll have even more access to the area and will see the outer airbox that smithsil is talking about.
Dassin
Teh Silver Bullet!
Poulsbo, WA
It's the plastic piece that's on the other side of the hole in the fender. Where the inner air box (where your air filter is) goes out into the fender, there's another box in there, maybe 1/3 the size of the normal air box, which has a cone coming out of the forward part of it. Some people (like me) remove the whole thing, and some people just remove / bust off the cone. In order to get it loose, you have to remove the inner airbox and get access to the 2 bolts / nuts that fasten the outer airbox to the car. Do that and remove the splash guard / inner fender thing (or just undo the forward half like I did) and it's a cakewalk. Enjoy your new, cooler intake sound :thumb:
ckinart
stevemainian said:
Im assuming there are screws holding the outher air box in? I kept pulling on that bitch and it wont give...
Corey
