Ok I think Ive found the source of my transmission leak but wanted to run it by everyone in case im missing something. Its a 93 ATX. Transmission was rebuilt at 116,000 now have 142,000. Ive been having smoke roll off my cats for a little while but now its leaking faster. Lost a quart in about a week. Its on the passenger side seems to be in the output shaft seal area. It has covered everything in fluid. I wiped everything down and tightened the pan up to make sure that wasnt it. Took it to town and back and had quite a bit of fluid dripping off down below the seal. Only thing is the axle itself really isnt that wet. Just kinda caked with dirt. Things above the shaft are wet also. Is there anything else above the shaft that would leak down this way or is the axle probably just flinging it up there? I am sure it is tranny fluid cause its nice and red and i lost a quart. I could see the VSS through the wheel well and it was dry up there. Any advice would be appreciated. Autozone said they had the seal for 2.99. Sound right?
