Transmission just died, need help with new setup
mcrowe3797
I would recommend a South Bend Stage 1 Clutch: SHO Source
The weak point on the stock clutch is the straps which can give way. I had a stock clutch fail after only a few hundred miles due to the straps. I have been running a Stage 1 clutch since then and it has worked great.
Is the cryo treatment really worth it since the clutch is a wearable item?
Cocoa,Florida
Stock 9.75,ceramic TOB.
There are several people here on the forum that can both sell you an MTX and weld or ring the diff for you.
AREA 91
PA SHO SHOP
Area 91
I found out the pressure plate was cast if that helps? I really wish i could find a used qualfie/wavetrack and not just weld the pins :( Its just hard spending 2200-2700 for a trans, welded diff, clutch labor and flywheel.
That is way too much money for that job!
