Transmission experts. I have a question for you.
kidrock52
I pleed the fif!
Buckley, MI
Ok. Please refer to the first thread I did this fall when my SHO quit... http://www.shoforum.com/showthread.php?t=37127 Now, I took it out of my garage and got it to start and let it run a while. Just for laughs I decided to try to put it in to reverse and it went backwards... I tried to put it into drive and it went forward... I got adventurous and drove it around the block. It shifted fine. I then floored it a bit to see if it would act up. It missed the down shift and just reved up the RPM's. But after I did that it drove normal when I let off the gas. I pulled it into my yard backed it in to it's spot and checked the tranny fluid and it looks great. Now seeing how it wouldn't move when I put it into the garage last fall what would make it work now? Any guesses? Thanks, Ed
Electricat
Decatur, IL
Just a guess....but it sounds like you took it out on the test drive cold...if you let everything get up to operating temps, your problem will probably come back.
