Trans Swap Write-up?
Dr.Evil
No Dif Pin!
Sparks, Nevada
Does anyone have a write up on how to swap trans/change clutch on the garage floor? I would get the SHOnut video but he is not shipping until after the convention and I would like to have my new trans in before the convention. Questions I need answered:
1. Where are the plans for the engine holder?
2. How do you support the car when the subframe/trans assembly are removed?
3. How high does it need to be off the ground for it to slide out?
Thanks
masho95
got Zex?
Chicopee, MA
It might just be easiest to make your own measurements and make a wooden support accordingly, which is what I did.
Use jackstands with wood and place them right behind the rear subframe bolts on the body rails.
Thanks
Just jack up the car as far as you can and support the car by the method in answer #2. That'll give you enough room to pull the tranny.
John
PA
yeah just make some 4x4 supports to hold the motor up dont worry about renting some engine brace or lift etc. check shotimes.com for a write up ..
the job is rough . i recommend having somebody with you to help.. also expect to be doing this for about 10 hours at least being that you've never done this before . also ive learned this the hard way . buy your motor mounts and tranny mounts ahead of time before you do this job.. because they are hard to get a hold of at the parts store.. and not only that if you order them sometimes they arent even the right ones. so i recommend ordering them on shonutperformance.com or midwestsho.com to avoid the hassle.. and if theres anything else thats buried that u even think might need replaced just get it and replace it ..
John
Dr.Evil
No Dif Pin!
Sparks, Nevada
Anyone have the plans to build the engine suppot? It would be helpfull to know what to get at the hardware store instead of making up my own design.
Bizzy
Thanks
PM sent
40BelowSummer
Puerto Rico
If you wait til I get home in a few hours I have some nice pics/plans for an engine support someone sent me a while back...
Dr.Evil
No Dif Pin!
Sparks, Nevada
PM sent, please send the plans ASAP.
Thanks a ton!
