SHOracer14
Me-0 Diffs-6
The SHO finally hit the road again on early Saturday Morning after a diff pin encounter. Thanks to Justin (foxwulfe) and Chris (speedy_91_sho) the car came back together (without them I don't think the SHO would have been in one piece again so thanks guys). Anyways I had a small coolant leak after it got back together but then dissappeared after it ran and got warmed up. It doesn't seem to be leaking coolant anymore but last night the "Low Coolant" light came on. Filled the reservoir today so I guess I will see what happens with that. The next mysterious problem is that I'm leaking a healthy amount of tranny fluid. I haven't got a great look yet (I'm heating the garage as I type this) but it seems to be coming from the driver's side, where the halfshaft goes into the tranny. Is there a seal there that can go bad or what? My other quick question is that the new tranny shifts perfect but if I want to shift fast (even when I'm not pushing all the power) it grinds in second. It doesn't grind if I shift normal though. Is this a bad synchro or what?
