Blackheart4355
Just wondering, when these bolts are put in, should there be some lock-tight or anything on them? The reason I ask is because I had my 94 ATX up on the hoist yesterday putting in a new fuel filter and while under the car I did my usual visual inspection and noted a pan bolt missing!! So I quickly grabbed a 10mm socket and ratchet to check the others. They were ALL loose, not really bad but loose enough to concern me. I checked the fluid level and topped it off but now I'm concerned these bolts will back out again on their own. Any suggestions?? frown
