Tranny fluid change?
elarm1
Maryland Native
Woodbridge, Va
I just completed my 60k along with valve cover seals and spark plugwell seals and I must say, this thing boogies! One little problem though.... When I push the clutch down I hear scrapeing and sounds of sand paper, it is also hard to put in gear. When I pump the clutch a couple of times, it goes into gear like a brand new car (almost), but I still hear the sandpaper sound. The clutch holds fine with no slippage. Can I just be in need of a tranny fluid change?
Cocoa,Florida
sounds like a clutch issue of some sort.
it can't hurt to change the fluid though,i like to use Mobil 1 ATF.
I got Castrol dex merc atf should that be good?
MERCON ATF is good. The blocking rings in my MTX did not like Mobil 1 ATF. I use the Valvoline Max Life MERCON with good shifting action even after all these miles.
AREA 91
PA SHO SHOP
Area 91
Now is the perfect time for the drain plug installed.
I do believe, that your throw out bearing is chewing its way into your pressure plate finger's. I bet you will need a new clutch soon.
thatSHOguy101
