MichaelH
ZEXman
I started hearing a thunk when I stepped on the brakes, driver's side front. I take it to NTB to look around. They find the trailing arm bushing is loose where it's connected to the subframe. They install new bushings, both sides. During the installation, they discover a piece like a washer has come loose from the subframe where the bushing attaches (the thunking side). The NTB mechanic calls Ford (local dealer, I assume) and Ford says I need a whole new subframe. Does that sound right? If so, how many millions of dollars will it cost to replace the subframe?
As of now I have wonderful new poly-urethane bushings, but the thunk is even louder. It's not dangerous, but very noticeable and very annoying.
<small>[ November 08, 2003, 02:14 PM: Message edited by: MichaelH ]</small>
