Towing car, without engine. Several problems with this...
Devin
3.Slow
Pacific Northwest
I just took the engine out of my SHO and I am going to be bolting up the subframe and maybe reconnecting the steering shaft. Will I need to reconnect the steering shaft to tow the car, or is it optional? Also, the wheels had lock nuts on them and I butchered the **** out of them. Can I tow the car without a tow dolly (ie: with just a tow bar), or should I go all out and just stick the front tires up on a dolly?
Grrrr, the farther this goes, the harder it is...
Slo-Sho
It wasn't me!
Crossroads, CNY
If you are going to be towing it on a dolly then it doesn't matter if the tie rods are connected or not. Save yourself the time and get the dolly.
93redATX
SHOForum O.G.
WI
^^^^^ What he said ^^^^^
In my experience, it is much easier to just tow it on a dolly. Be prepared though, as you will more than likely rip your front bumper cover if you're not careful. I did. Twice. On two seperate SHO's :(. Plus I destroyed two SLO bumpers off loading the cars from the dolly. squint
