Torque Specs
sholooking
Does anyone have the torque specs for the power steering bracket to block bolts and the AC compressor bracket to block bolts? Or is it just good & tight. Also the power steering pump to bracket bolts. Thanks in advance.
sholooking
Thanks Scott. I just finished reading your other post on the nightmare of changing the power steering pump with the engine in the car. I was wondering since I'm replacing most items on my replacement engine while it's easy to get to, would you recommend changing the o-ring you mentioned, on Pwr Steering pump suction tube as preventative maintenance or better not to mess with it since the pump is not leaking or causing any problems? Thanks
