petedogg
I will be replacing my torque converter soon, to fix the shudder I am getting and my code 1744. I am getting a rebuilt converter with welded internal splines. Are there other parts I should replace while I am in there, short of doing a full rebuild? Is there a seal next to the converter I should replace?
I am strongly considering replacing my pump shaft, since that seems to be a common failure. What other parts will I need to do this right? Any other common failure items that I should replace? I'm not looking to go overkill on this, because by budget is tight and the car already has 120k miles.
Also, I plan to replace it in my garage. Any recommendations for the height I will need on my jack stands? I already have a support to hold the engine, and plan to get a transmission jack adapter for my floor jack. Thanks.
