Tons of lights flashing!!!
ghostrider
Mt Juliet, TN
These past 3 monthes haven't been to kind to me where cars are concerned. Just no good luck at all! Anyways, I was driving myself and a friend home tonight, when I noticed the Check engine light come on. Everything somnded ok, no changes in the way it drove. 5 minutes after that my battery light came on. Now the CE light went off after a couple minutes but came back on. The battery light though was kinda wierd. It would get pretty dim then get very bright. It was blinking erratically. When I got a chance to stop I kicked on all the accesories and couldn't notice any diming of the lights. Checked battery connections, and they were practically corrosion free and also very snug. I need to run the KOER and the KOEO test to check my codes for the CE light, but anyone have an idea about that batt light?..... Strange things are afoot here at the circle K!
To illuminate the BATTERY light, the alternator is not putting out the minimum required voltage. Either the brushes are worn out (likely), the voltage regulator is failing (not too likely) or there is a short in the windings (unlikely).
ghostrider
Mt Juliet, TN
Well I don't know if this is good or bad, but this morning when I started the car the batt light did not come on again. So I will have to keep an eye on things and see what happens.
FatherOfTwins
Simsbury, Connecticut
Here's some advice from someone who has battled the Battery light on 3 separate Ford products, a Taurus/Sable/& SHO, and won each time. After screwing around with alternators, I finally figured out what was really happening. On top of the alternator there are 2 factory connectors that attach directly to the alternator and then jump over to the frame above the radiator and become part of the wiring harness. One of the connectors is large (with 3 or 4 wires) and one is smaller (with 1 or 2 wires). After years of driving your car with the engine rocking back and forth on the mounts, the braided wires in these connectors or near the connectors break inside and cause an intermittent loss of alternator charging. This starts out as a flashing Battery light, and eventually ends in the Battery light staying on all the time. At this point, the alternator stops charging the battery, and pretty soon you will not be able to start the car. In all 3 cases, the broken wires were in the smaller (1 or 2 wire) connector wires. I have a 1993 SHO which uses a Mitsubishi alternator- therefore the connector wasn't available at Ford. So instead, I cut the connector off the wiring harness about 3 inches back and took the connector apart and replaced the wires. Then I reattached the connector to the wiring harness and now its good as new. If you want to conduct an easy test to see if what I explained is happening on your car, take 2 clip leads (alligator clips) and attach one end of the clips to the 2 terminals inside the connector on the alternator and then shave the insulation off the wiring harness about 3 or 4 inches back from the connector and attach the other end of the clips there (make sure you attach the clips to the right wires though! otherwise the car will not start!) If I was a millionaire, I would bet you a million dollars that this will end your Battery light problems. As a final note, a guy I work with owns Mazda's clone of the Ranger pickup- and I diagnosed the same thing on his truck too.
