Tokico strunts
SHOisfun
North Carolina
Well I called Fast Track about the Tokico inserts. Appears there ain't no more. Any ideas? I've got two rears going out.
FREAK_SHO
Wisconsin
Koni inserts in stock housings. Not sure if you can install the Konis in Tokico housings.
Dave
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
yeah.... do you have tokicos right now that need replacement? or are you looking to upgrade your stocks... do you have lowering springs, and/or are you looking to get some in the future?
SHOisfun
North Carolina
Trying to find Tokicos
I've got Tokicos and Eibachs on my 93 but the two rears have gone out. I lost a front one last year. So, I'm needing to find a couple rears for now.
greenbeanmtx
King Skidmark
Waco Tx
There is a thread on here somewhere that has the part numbers where you can buy a replacement tokico insert thats specifically for tokico struts. Thats supposidly the only way you can do it with those now.
noSHO4u
Bartlett, IL
The problem is that you cannot find the inserts anywhere!
Does anyone have a line on where to find the inserts?
The part numbers are:
Front Tokico Cartridge: P/N HZ3130
Rear Tokico Cartridge: P/N HZ3131
noSHO4u
Bartlett, IL
If anyone can find a shop that has these inserts in stock, I know of at least two people that will gobble up a full set of inserts.
noSHO4u
Bartlett, IL
I did the google search, called the first 5 hits, 3 of the 5 said they dont have them, 1 said i was crazy and that part number doesnt exist, and the 5th one didnt even answer.
I'm hoping that someone else has better luck than me.
