Tokico/ Eibach install Casualty
OSU 4 SHO
Westerville, OH
Installed tokico/eibach in the front yesterday and forgot to put in the pinch bolt holding the hub to the lower control arm, and the wheel and hub came off of the lover control arm. This made a brown slimy liquid come out of a mount of some kind on the drivers side of my ATX. When you take off the tire, it is straight ahead. It is a circular shaped mount that might be a tranny mount, but it was leaking a brown fluid. What is this mount? Does it have a fluid in it? Should I replace it since I must have broken it? Thanks, Aaron
3.8Lwagon
Shaggen Wagon
the mount is like 51.95 from autozone and it has a lifetime warrenty.
fyi: you have to remove the 4 bolts that hold the trans to mount bracket and the 2 that hold the mount to subframe bracket. Now is a good time to check the other 2 motor mounts.
