Tires !!
bpd1151
Lurking Around
SHOcago 'Burbs
That ass of yours is so hot, it's damn near occluding the image from all the steam rising from it.
RAWR.
Hahahaha.
Still looks sick though all joking aside.
StealBlueSho
NA
Love that setup Andrew! Your build is quite something and has turned out to be one of m y favorites to watch! Excited to see what you are able to turn this year at the track.
He will click off the first 10 in the platform. I have zero doubts.
76FoMoCo
Nampa, ID
I have been looking for a 100 utqg rated tire that will fit our cars and not luck! I have the bridgestone 007a and its a 240 utqg tire and my 60's need some help as I am always around 1.88 to 1.92. Anyone know of a 100 utqg tire?
76FoMoCo
Nampa, ID
The toyo proxxes are 100 but of course they probably have limited size. Just track days?
And daily. I know thats not good on them but summer use and the track on the weekend I just look at them as one summer use and done.
Get some Conti's. The Extreme Contact's are amazing at the track and on the street.
I don't know how much I would trust them in the rain. If you are intent on 100 maybe you can find a viable alternative rim size to accommodate that kind of tire? You really need to contact a tire specialist (or 3) to find something that is that niche and specific...and then post back and share!
76FoMoCo
Nampa, ID
The toyo 888r as suggested above are looking good but they only come in 27 in v stock 28.7. I'm thinking the lack of sidewall will not be a good thing.
Just waiting for Jorden to spill the magic sauce.
Jordan runs on a drag radial at the track. Andrew has gone 11.3x on the Conti's. I went 1.77 to the 60 foot on the Conti's with stock suspension, and stock rims.
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
I wonder.....is it true that some ppl have swapped to a drag radial or slicks and bc of the excellent traction they all of a sudden break stuff? Makes me think maybe it's a good thing to have a little slippage.....
ticoscen
275 40 20 Michelin Sport 4S's with 20mm spacers. No interference on front.Minor interference on rear. Fixed the rear wheel well rub with a heat gun to reform the two plastic formed nub areas and hammer to tap in a couple of metal tabs. Tracked the car at VIR last friday without problems.
I use the 10's for drifting.... :)
