Tire weight
fredhurderjr
www.neshospecialists.com
FYI only, I weighed my new BFG G-Force KDW tire that came in this week. It was 26 pounds for the tire itself, at 235/45-17.
White 95 SHO MTX
"Jezebel"
Spends more time in the shop than in the driveway
Teases me with occasional great runs
3.2L SHO Shop Long Block
9psi Vortech S-Trim Supercharger (12psi on the way)
Eibachs, Tokicos, 96 Brakes, SFCs, STBs
PP Y-Pipe, Custom Stainless Cat-back, Bullets
http://members.home.com/fhurderjr/sho.htm
Mocha 91 SHO
"Monique"
94shoboy
south shore, mass, usa
damn fred, isn't that more then the wheel itself? i have BFG comp ZRs, i wonder how much they weigh. i will be taking the tires off in the spring to install sensors in the wheels. i will have to find out then. did you ever find out how much the rim 2000s weigh?
fredhurderjr
22 lbs, according to Team Dynamics, although they said they used something like a bathroom scale, and expect the actual weights to be slightly less than published weights.
RI-SHO
B to the BANNED
Pawt., RI
So with tires your whole wheel weighs in @26lbs right?(i'm a little lost) So the tires would only be 4lbs, which would make the RIM2000's @22lbs like u said. Also Fred I belive your rims(17"X7.5") should weight only like 20lbs. Because i was told by Team Dynamics that my 18"X8" Motorsports weigh 24lbs ea.
Click & See My Modified 1993 MTX SHO
fredhurderjr
According to the weight chart I have from TD, you are correct - 18x8 Motorsport = 24lb. Their heaviest wheel is the 18" Diablo.
Their lightest 17+ = 17" Qualifier at 19lb (no SHO fitment though), or the 17" DTM at 20lb (fits SHO, but being discontinued). These do not count the new lightweight forged wheels they unveiled at SEMA.
RI-SHO
B to the BANNED
Pawt., RI
I only WISH tires weighed only 4 lb Edien!
I was lost from the begging so me was just guessing
. But thx for the reality check(lol). BTW do my 40series way less(less rubber) than your 45's or actually the same b/c they are made differently to be stiffer?
______________________________________________
[This message has been edited by RI-SHO (edited 11-17-2001).]
fredhurderjr
I guess you could ask Pirelli what theirs weigh. I'd hazard a guess it would be a couple pounds lighter, but not that much so. Yours are smaller on the sidewall but a little wider (at 245, right?)
RI-SHO
B to the BANNED
Pawt., RI
Nope 235/40/18 My next set of rims will either use my current set of tires, if no one decides to buy my wheels like before. Or 245/40/19 if i do sell my wheels(extra $ for rubber), plus the new rims will be lighter. New rims for RI-SHO are confidential to further notice
DeaconBlue
Cleveland, Ohio
Here the weights of the three sizes of Dunlop SP5000 that I have run.
215/60-16 23.2 lbs
225/55-16 24.5 lbs
245/45-17 24.9 lbs
95 MTX
with a few mods
