Contrary to popular belief, tire pressure doesn't change based on weight. Do an experiment yourself if you don't believe me. Take the pressure of the tire when the car is on the ground, jack the wheel off the ground, and then take the pressure. Both will be the same even though the weight on the wheel changed dramatically.Max pressure on the tire is at max weight rating. You're no where near that unless your car is full of people and the trunk is full of lead
See how it does at 36-38. And watch your tread wear![]()
Yes, if volume changed pressure would change. But volume isn't changing. A tire makes a flat spot on the tread area when on the pavement but the sidewalls also bulge out a little bit. Any volume decrease from the flat spot is made up by a volume increase by the bulging sidewall. No total volume change makes for no pressure change.Tire pressure would change based on volume. If the tire is compressed, pressure would increase. But I think in a typical automotive scenario you aren't going to compress it enough to make any appreciable difference.
