Hey everyone, tried tires at 33 cold all week long and in the morning (8am) on the way to work the ride was much more comfortable but as far as handling I would say it was a little sloppier, less responsive and a little less direct. However, on the way back from work it was still more comfortable than at 35 psi but now it felt really responsive and grippy. Also no abnormal tire wear so far...
Then, this weekend after being on the interstate for a while I stopped at my friends place and picked up some dust on his driveway and we could see that tires (especially rears) still had about almost an inch from each shoulder that was not in contact with the road (like they were still overinflated) so he used to have 96 SHO (with the same Gen3 wheels I have) and he told me recommended pressure on Gen 3 was 30 psi all around (COULD SOMEBODY WITH GEN3 VERIFY THIS PLEASE?). Anyway, I decided to drop the pressure to 30 psig cold and ride home on the interstate was very comfortable, and for the first time since I put Tokicos it seemed nice on the interstate, not too bumpy and all, but then I tried a corner at about 80 and the way the rear acted really scared me... Really loose and wobbly and all around I could feel the sidewalls flex. On one open stretch I tried to quickly merge lanes and the steering feels really disconnected almost like if I had a flat tire. Also, after the ride all 4 tires felt really hot that is definitely a sign of underinflation...
1) I would still like to hear from you how do you decide what pressure to run as obviously low pressure makes a big difference in how comfortably the car rides on the interstate but gives more side play for the sidewalls... My old tires at 35 psi hadled good, very bumpy, but wore a lot in the center so I was trying to figure something better with my nice F1 GS-D3s...
2) Finally, how do you compensate for a temperature difference in the morning and afternoon? 33 psi that felt low in the morning, at 5 pm was over 36psi and felt good and responsive. Does that difference average out the tire wear as when it's cold it wears the outside more and then when it warms up it wears in the center more?
3) I did a lot of reading on this on Tirerack's site and it talks a lot about carefully checking pressure in the morning before any ride to match the factory specs, but then I don't really have the factory setup any more... Also there, I found out that BMW 330i with similar weight, suspension like on mine, and 225/50 16s recommends 29 / 33 psi front/rear... again an argument to lower our pressure from 35 psi. And why keep the pressure the same all around and not put more in the front?
Sorry for the long post but I waited for a week to get some more experience running the lower pressure
Thanks for all the help so far
This is killing me :headbang:
