Timing Question... NEED HELP!
1993TaurusSHO
I am changing the timing belt and cam seals I took the belt off and have changed the seals... when I took the belt off I know it was in time... but when I went to get the bolt out the engine turned...but not the cams...so I know I will either put the engine in time or 180 degrees out....is there any other marks to check the timing on the crank or do i have to take #1 spark plug out and see if the piston is up????? Thanks for the help
K-Dawg
Treasure Coast, FL
There is a mark (dot) on the crank timing belt gear that lines up with a mark at about 5 o'clock on the oil pump housing. When this is lined up, it puts the motor at TDC. Doesn't really matter if it was previously the intake or exhaust stroke.
Here is a link to a Forum topic with great photos of the alignment marks that need to be set to properly install the belt and synchronize the camshafts with the crankshaft. If you don't have a procedure for this service, you really need to visit the AutoZone.com webiste and look up the timing belt installation repair guide.
http://www.shoforum.com/showthread.php?p=72252#post72252
