thumpida
89 mtx 96,000. i think i might have killed my timing chain and or tensioner. the other day i overheated and seriously cooked my oil. as soon as i got it cooled down to a reasonable temp i got a bad ticking from my engine, my first thought was rod bearings. now that i got my steth out it seems the noise is loudest at the front drivers side cylinder.it sounds the same on that part of the valve cover as the timing chain. though upon further inspection i can hear what sounds like a bike chain dragging across a bar along wiht the ticking. it is proportional to the rpm. feather the throttle at the right points and the ticking stops. also performance seems to have dropped(disrupted timing on exaust cam?)i am not currently driving it. btw i have no oil level or pressure problems. as i understand it i can safely drive with the tensioner bad just lots of noise. however it prolly needs a chain. how much are these and where at? how difficult are they to change? i need to pull my intake and do the valve cover gaskets anyway.
