NemoX
how does the timing belt tensioner work? i just had my timing belt walk off the rear cam sprocket and the tensioner is now flopping around. doesnt seem to be spring loaded any more and can be moved freely in all directions, i.e. angle w/ the engine will change. the nut off the end is also missing. what am i looking at replacing? i have the tensioner off a spare engine and it doesnt seem to have a spring on it. this is kind of an emergancy repair as i am to move to florida when i get off of work on saturday night and i kind of need that car...
andrew
forgot to mention, i just had the belt off to replace the front crank seal and i didnt replace the belt because of time contraints. what is the proper procedure to loosen the tensioner? i loosened the center nut and then turned it w/ the allen wrench. does a new tensioner come w/ that nut ?
andrew
