I figured i'd post here rather than start a new thread.
I took everything apart, and it was going way too smooth other than the rough crank bolt head. Then I noticed my rear bank headgasket definitely has to be seeping oil. It seems minimal. I noticed it on the driver side, but I thought it might be wicking there from somewhere else. I never got a look at the pass. side until tonight and it looks like it's seeping also. I guess i'm going to try and forget about it until it gets bad. I found another user had a similar problem when I searched.
Anyway, I also messed up when I removed the last cam seal behind the cid sensor. I was tapping the pick and it slipped and went in between the cam and seal. Am I screwed now?
I looked at it to try and see if I could notice anything, but I can't. If worse comes to worse and I start going through sensors is there a sleeve kit that will fit that shaft? Would it be possible to put the sleeve kit on without taking everything else back apart if need be in the future? Surprisingly the only seal that was leaking was the crank seal.
Thank you again i'd be in a lot worse shape without you guys and this website.
Next time maybe i'll make the right choice and get a decent SHO, i've already put 2k+ into this one.
