Time for a speaker upgrade - NOW WITH PICS
Christian
Chilliwack BC CANADA
And by the way, the new speakers are AMAZING. What a difference. I quickly hooked up the sub to check it out before properly installing and also sounds so good. More details and pics when I'm done.
Thanks all for your help.
Christian
Well.....shit. Finished the install and cranked up the system for 5-10 minutes and it all sounded so amazing. Then...the driver side front speaker stopped working. WTF? Took speaker out and quickly hooked up the factory sony and it worked. Checked the resistance on the BLAM and it's well....gone blam. Meter reads "0" I'll take it back to the shop to exchange it (I Hope they have another set). Didn't expect that from a quality speaker.
Christian
Took the speaker back to shop and they exchanged it. No problem and they said this was the first issue they've had. I agreed that it was probably just bad luck. Here's some pics of what I did:
The setup:
1. Hertz 5x7 for the rear doors. These are real nice speakers. I love that the tweeter can be rotated to point towards occupants. I find that this allowed for improved sound for those riding in the back seats...or when I'm back there with my wife - now she can really hear Marvin Gaye whispering in her ear... lol
2. Pioneer 3.5 inch for the front center dash and rear center shelf. They dropped right in without any mods. I find that the tweeter helps with staging and takes out a lot of the muddiness. I'm glad I didn't skip this addition/change like some had recommended.
3. BLAM 5x7 components for the front doors. Just like their sister Focal speakers, these are beautiful and well made (ignore the fact that I had ****** luck with one of the woofers). They sound amazing..full and rich. The tweets perform wonderfully. Crisp and smooth.
4. Scosche amp kit. Nothing special....8 ga power wire, etc. Ignore the "Blueskin" sound deadener...I returned it. It was tar based. More on this later.
5. The star of the setup...a Scosche 10" powered sub. lol. It's good enough for now. I may replace it at some point, but I gotta say, it sounds fantastic compared to just the 6x9's the SHO came with. I left the 6x9's hooked up and think of them as a a regular woofer. This sub has good deep bass without being obnoxious. For me, it's perfect.
First thing I tackled were the center channels:
20190419 151839
Super easy to replace the front. Just unclip. The rear was another story and I found that was the hardest part of the job. This is the factory speaker20190419 152051
And the new Pioneer installed. Again...super easy. No trimming and no wizardry.
20190419 155537
Next up...ugh...the rear center. Lots of acrobatics to get this one in. At the end, I didn;t even completely remove the rear shelf. I just pushed up on it to get at the screws holding the speaker in.
20190420 094837
Next up was the rear doors. Following the Youtube videos, these doors are easily removed. The only caution here is the clips. They CAN break. It wouldn't be a bad idea to have some replacements on hand. I was fortunate and only broke one of all four doors. as you can see I rotated the tweeter so that it faced the occupants. IA nice feature on these quality speakers. I lined the inside of the door with XMat. It's a fraction of the cost of Dynamat.
20190420 111328
20190420 125159 20190420 125224
Next up..the front doors:
20190420 164020
Again, Youtube is your friend. Very easy to remove the door panels. Just use proper trim tools (plastic). I got mine from Harbor Freight for cheap.
Here are the tweeters installed in the C pillars. The BLAM tweets fit like a glove. They literally popped right into the existing recess of the pillar. To ensure they stayed secure, I simply zip tied them in place. I installed the BLAM crossovers right next to them with 3M double-sided tape (where the harness plug was before I snipped it off).
The C pillar panel removes easily. They're mounted with clips at the top and ,iddle and then tabs at the base of the windshield. Once the clips are popped, you just firmly pull up and away.
20190420 160124
Here's a comparison of the old and new speakers:
20190420 135616 20190420 135623
The woofers are butyl rubber and even the magnets are coated in rubber. The tweeter parts were all coated in rubber as well. Even the mounting parts. Beautiful craftsmanship through out.
Lastly, the sub. I ran the power from the battery down the firewall. I could'nt find an existing grommet and wasn't prepared to drill a hole, especially with how toight it is under the dash. Soo I ran the wire down against the firewall (outside), and the drilled a hole in the sill plate and ran the wire through a grommet. Then, ran it along the sill plates to the trunk:
20190421 191905 20190421 191914
And here is the sub mounted in my trunk:
20190423 153038
I had many options here. I decided to mount it with some L brackets I painted black holding it up underneath (drilled into the metal of the car frame). Remote wire I ran alongside the power cable to a T Tap in a wire under the dash.
All in, it took me about 6 hours. It was actually fairly enjoyable..even with this 58 year old body doing contorsions I haven't done since I was in the military. LOL. Am I sore today? Oh yes. Yes I am. But I've got Marvin Gaye to lull me into a comfy nap in the back seat....
iugolf247
Greenwood
Thanks for the pics... I have been thinking of upgrading the speakers in mine. This helps a ton!
Christian
You're welcome.
May as well update my experience. So far, I find the sub...lacking. As correctly pointed out by others, the Scosche sub, while a great value, just can't project enough sound through the well-insulated cabin. I could of course, lower the seat backs, or make a pass-thru in the rear deck or ski hole/arm rest, but I 'm not into that. Instead, I'll watch for local sales and get a sub and amp and build my own cabinet. The bass roll off from the stock amp is also proving annoying. I may have to look into an amp and processor down the road.
Hello rabbit hole..............
Lostneye
NY
You're welcome.
I have the PAC amppro to get signal before the factory amp. It works well and maintains the factory amp so you can power whatever speakers you still want to keep on it. Tried the Rockford DSR1 prior and while it has a build in DSP it was buggy, very noisy and never sounded as good as the PAC and separate DSP. It also replaces the factory amp so you would need amp channels for every speakers yo are keeping. Very few DSPs will do proper center channels so if you go that route you can get rid of them and shouldn't miss them.
