Dual Plenum92
how do you tighten a flywheel without having it move around and without having the flywheel tool used for this specific application?
thanks DP92
thanks DP92
SHO--ripper said:put a 19mm socket on the crank bolt and rest the wrench on the subframe. That will keep the crank from turning![]()
DHMag said:heh...uhh..yo ? flywheel, not harmonic balancer![]()
autobahnsho said:oh-
and aren't you supposed to LOCTITE the flywheel??
