ticking
poissonverte
iowa city, ia
This is interesting (might be me) but it seems theres a ticking coming from the top of the motor. If i stick my head on top of the intake it sounds like its coming from where the fuel rails are? really weird.. Hard to diagnose w/out hearing it i suppose but random ideas are always. Sound like taking the end of a pen and tapping it on wood.. hmm
93 ATX
124K
MODS: 4 slicers, 2 stickers, license plate, fog lights, moonroof, cd player, rear spoiler.
Next MODS:
Sitting in their respective box
Rob94
Northbridge MA
Probably just the fuel injectors doing their job, which in a nutshell is opening and closing faster than all ****.
Rob
White 94MTX
K&N Filter otherwise stock
T
Tommy the Greek
Guest
I hear the same ticking in my car and was told to change the spark plug wires. Since they are the original ones I will change them sometime before spring. I bought a set from www.fordpartsnetwork.com for $134.99. The dealer wanted over $300......like there made of gold or something.
SHOPhear95
south SHOre mass
I have the same ticking going on, some say it's the injectors, some say it's my valves. So i'm getting my heads rebuilt
there about due for a valve adjusting
Matt S
1995 ATX
Custom 3in catback with Vortech mufflers
Intrax lowering springs
Sho-Shop lpm
Sho-Shop CAI
B&M Trick Shift Synthetic ATX FLUID
Mille Miglia Action with 245/45/17's pirelli p7000's Supersports
rebuilt ported n polished heads and 3.0 intake cams coming to a SHO near you!
Two Yamaha powered Intrax stickers
It's fast as F#%&!!
"Attention passengers, we seem to be experiencing some Godzilla related turbulence. just sit back and relax, when we reach 30,000 feet he usually lets go"
SLOSHO89
San Luis Obispo, CA
Worst case senario.... You need heads. But it could be that you need to have the valves adjusted.
How loud is it?(very loud, or just like little tapping)
I personaly don't see what good changing the spark plug wires would.
Good Luck
Slicers, SHO+ hood and spoiler.
SHO SHOP Y-Pipe
Silver-Blue '66 Mustang Fastback
E-mail, [email protected]
AIM; SLOSHO89 I like to talk SHOs:)
If it is a valve tappet on cylinders 4-6, unscrew the oil fill cap on the front valve cover and listen for a tap. If it gets louder it probably is a valve tappet. Even if it is the injectors, if you have never had a valve gap adjustment, you definitely need one after 124,000 miles.
Scott
poissonverte
iowa city, ia
hmm take off the oil cap never thought of that one.. ill try that and see what i hear(after it snows).. had the valve gap done in May. Its not that loud of tappingn just more noticeable when the hood is up. thanks for the info.
93 ATX
124K
Next MODS:
