Yea it's comeing from the timeing belt end.sho 'nuff said:That is a good possibilty. I experienced the same noise and the tensioner is what it turned out to be. Have you tried to narrow down where the sound is coming from under the hood?
yep, same thing. Fixing tommorowBlack '93 said:did you see more slack when the sound was there and less slack when the sound goes away? I'm having a similar problem.
Mine was $173.michaelcz said:how much was the tensioner from ford for the atx?
Just the tensioner cylinder. The part that pushes the idler onto the belt.michaelcz said:Is that the whole timing belt tensioner part?
This part.SHOdownTN said:Just the tensioner cylinder. The part that pushes the idler onto the belt.
SHOdownTN said:yep, same thing. Fixing tommorow
Not that I know of but while looking and makeing sure the belt was in the cogs, one sliped and threw the timeing off. I went ahead and re timed it, probly best to do or atleast check while your at it.michaelcz said:was your timing off after replacing it. If so what did you have to do?
Well you have to locate the timeing marks on the cams and the crank and line them up with their marks. A book or picture would help you more.michaelcz said:How do you retime it?
