dpsutphin
The connector for the TPS in my 3.0 was bad (two badly crimped wires), I found a connector from a 1994 3.2 at a wrecking yard and spliced it in carefully being sure to get all the wires in the right place. Although none of the colors match on the wires, the connector will only go on one way, so it was easy to get them matched correctly.
The problem is that the check engine light will not go off. I still get a constant code 63 (TPS circuit out of range). I guess the sensor itself has gone bad, although it was fine before I started on the 60K about a month ago.
My questions are: Could the different connector cause this problem? And if I get a new sensor, should I get one for the 3.0 engine in the car, or one to match the 3.2 connector, or are they both the same?
