throttle cable, anyone have a decent one?
Mike92Silver
Bensalem, PA
my car has never been the same after the cable was replaced with a used one from a 91, technically it says the 91-92 use the same cable, however, it doesnt have the feel the 92 did. ITs like im pushing thru the pedal and the car isnt accelerating any faster, its the weirdest feeling, i replaced the TPS also, no change. Before i used to punch it and the car responded immediately, now its like lagging or something and its not the engine, ive been over it a thousand times, its something weird with the cable and how its delivering the power or what not. Partial throttle is ok, but its like when u got WOT, theres no transition if that makes sense, i guess no tension in the cable itself? like its not tight! basically, when i go from partial to WOT, the rpms really arent climbing as fast as they should,its like from 3k in thirdgear, the car used to take off, now in third gear at 3k, i just watch the tach, go up at the same rate of acceleration, u hear the secondaries open up, but its like a slow opening of them, like the throttle isnt opening all the way, however when i check the cable, it does open all the way when the car is in neutral when i put the pedal to the floor, but once in gear, im not sure if it is opening all the way or not! damn car! i wish ford just make a new cable, that way i can rule it out!
CLIFF NOTES: throttle cable replaced with old one from a 91 SHO(my car is a 92), seems like the car has lost power, or its not going WOT.
Check that the trottle is fully open when someone is holding the gas pedal to the floor. Please don't do this with the engine running.
Copied from this this post:
There are three major components in the connection from your foot to the throttle plate. They are the gas pedal, the throttle cable and the throttle shaft on the throttle body (TB). You, and only you (or your mechanic), can check each of these components independently for restriction.
At the throttle body, use your hand to rotate the throttle shaft to fully open. Did it rotate freely against the spring pressure? If not, you need to clean the spring and shaft areas with intake or carb cleaner and relubricate the spring and shaft with a light oil or motor oil.
If no resistence in the throttle shaft, with the throttle held fully open with one hand, use the other hand to push and pull the thottle cable. Does it move freely or is there friction? If it does not move easily, you can remove the metal anchor on the end from the throttle shaft plate and the cable from the mounting bracket. The cruise control linkage snaps off the throttle lever. Examine the connector to see which way to gently push to remove it.
With the cable free at the TB, raise it as high as possible and use a lightweight spray lubricant (NOT WD-40) with an extension tip to fit in the rubber boot on the end of the cable. Spray the **** and try to exercise the cable to distribute the **** down the cable. You should do this until the cable moves freely. If you cannot, you may need to completely remove the cable and try again or replace the cable (if you can locate one).
If the cable moved freely, you need to examine the gas pedal and its lever to find if there are any restrictions or interferences to its motion. The pedal has no spring of its own and should move very easily. Remove obstructions and lubricate the pivot point as necessary to free the motion of the pedal.
poffffd
