throttle body
Alan
Arlington, Texas
OK I did a search and could not find the answer to this question. Will the throttle body and IAB off of a 91 sho work on a 94 ATX sho?
thankyou
alan
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Alan:
thankyou
alan
The throttle actuation is a little different, along with the cruise control cable, IIRC. I think the physical bodies are the same, its just the actuation setup that is different. Someone else may know better!
jthomas68
Area 51
The throttle cable will not line up.The mounting for the ATX vs MTX are a few inches different in length,and they are offset a bit from side to side also.As Autosho said,if you change the brackets,and throttle body housings appear to be the same.However,there are also different parts #`s for each,so they are not identical,although i do not know what the differences are.Also,if you look at the butterfly plate,there is a small hole in the ATX one,the MTX has this hole spotted,but is not drilled thru,does anyone know ther reason for this?
<small>[ October 13, 2002, 08:33 PM: Message edited by: jthomas68 ]</small>
