throttle body cleaning
Michael R. Rudel
Pinckney, MI
how do i clean my throttle body and MAF? i've searched and found various, often contradicting pieces of information. i was hoping someone could post the entire procedure, from start to finish, for me, preferrably scott and at least one or two others. :)
thanks
(mrr, now at 106k miles, still going strong, 60k coming this winter)
jthomas68
Area 51
You are not supposed to clean the throttle body,you should have a yellow sticker in it stating so.That being said,i pulled the shaft out,greased the bushings and ran a drill thru the hole by hand to clean up any burrs.
Mr Anonymous
Tire Wall
Gumout makes a new throttle body cleaner that specifically says it's for use on coated TB's. It's cheap, simple, and the directions are right on the can. It ran about $2.99 at Pep Boys.
scott c
central florida
I cleaned the absolute crap out of mine with the B12 stuff when I was doin the intake as I wanted to paint it. I was unaware of the warnings not to??????????? eek! eek! eek! What did I do and what would be the symtoms oh_my oh_my Could I have messed something up???
jthomas68
Area 51
No,it`s just fine.I`m not even sure what the coating is,but i have doublts as to how well it still holds up after 100k miles.
Markus
Ottawa, Ontario, Canada
jthomas68:
It's a teflon coating and it holds up just fine. If the coating is removed the TB will just have to be cleaned frequently.
Bizzy
I too have cleaned mine with Berrymans. At 167k miles she's just fine.
JT...where you find all these stickers man? :confused: (plastic hood, don't clean TB) Never seen the first one on mine... :p
Edit: Disconnect the MAF connector. The MAF sensor can be removed by taking out the screws (if you're lucky like me they'll be a phillips head). Once you take those out carefully remove the sensor. Spray from a ways away the 2 tiny hairlike wires with Berrymans (or carb cleaner). If you use a K&N filter, you'll see the oil build up on it from the filter. They'll be shiny silver when they're clean. I would not touch them with your fingers and I would not drop the sensor. They look fragile, but I'm not sure how fragile they are.
<small>[ December 02, 2002, 07:59 PM: Message edited by: Bizzy ]</small>
