gregr
OK. First I want to say that over the weekend I performed the valve adjustment portion of the 60K service. All seemed to go OK, and on the test run the car ran great!
On my way to work this morning, some strange stuff started to happen. CE light would come on, and the tach needle would jump all over the place and then would settle down. The car would run great for a stretch of several miles or so, where I was not shifting of doing hard acceleration. Then the Jumping needle turned into the tach dropping to Zero ad the engine was not firing. Then it would kick back on while driving.
I have a good feeling that this is CPS related, but would like all of your input on this. During the service this weekend, the front end of the motor was not touched at all. However, when the intake was off, the actual CPS connected may have been moved around a bit.
CPS? Maybe just the CPS connector? HELP please! I may not be able to make it back home from work. I would hate to have to live here at work!
Thanks in advance guys.
Greg Raciti
SHO Forum Webmaster
93 Emerald Green MTX
Performance Plus high flow stainless Y-pipe
Scott 2.5" Stainless
Exhaust with Edelbrock mufflers
SHOShop Cold Air Induction
SHOShop Underdrive Pullies (to be installed)
Romar Enterprises Subframe Connectors
SHO NUT Performance Aluminum Subframe Bushings
24mm front sway bar
26mm rear sway bar
Energy Suspension poly bushings
SHOShop LPM
SHOShop UDP's (coming soon!)
IPT triple gauge pod with Autometer - Volts, Oil Pressure, and Water Temperature Gauges
Greg Raciti
SHO Forum Webmaster
24mm front sway bar
26mm rear sway bar
SHOShop LPM
