Thermostat
Xs SHO 1
Unknown
McHenry, Illinois
when replacing t-stats, does one use a "non-hardening" Form A Gasket Sealant made by Permatex? according to shotimes, there isnt a gasket when replacing the t-stat. any help is appreciated.
thanks
pjtoledo
'ol man in the SHO
toledo,ohio,usa
The thermostat has a rubber O ring around it, there is no gasket. To prevent corrosion I coat the mating surfaces with some grease.
Perry Toledo,Ohio
pjtoledo
'ol man in the SHO
toledo,ohio,usa
xssho1:
what kind of grease?
Any kind of general automotive grease that can be applied in a thin film. The purpose is to coat the metal surface and keep outside water out. Has no effect on sealing the coolant it.
Perry Toledo,Ohio
Yamaha V6
SHO Enthusiast
Rhode Island
You don't need sealant or any kind of gasket material when using the Motorcraft thermostat, as it comes with the rubber ring around the outside edge of the t-stat ******. When using a non-motorcraft, reuse the rubber edge ring from the previous one.
I recommend only the motorcraft personally, but there are a couple other brands that have been listed here on SHOForum - like the Shaw one, I believe.
I don't use grease or any sealant at all, and have had no problems to date. I've always used only the Motorcraft, though.
Xs SHO 1
Unknown
McHenry, Illinois
on the motorcraft t-stat that i bought, it has "two dimple holes with loose pins" on it, does it matter if this goes upwards or downwards?
thanks
