Hank F.
I just got a 52mm T-stat for my 93. It came out of a car with 94k miles that is 2 years newer than mine (95). However, it has none of the air toggle holes, despite everything else being copacetic. Should I install it as-is? Or drill a tiny hole for the air to bleed through? I'm stumped. The car it came out of ran like a watch until it was sideswiped 10 days ago. Please any Jedi wisdom will be greatly appreciated. I need to drive to Alberta again, and it's supposed to be damn cold up there this week, so I DO NOT want to be stranded in Monarch or Lundbreck or one of those other minor metropolii that dot the landscape in the wind swept prairie that is Western Canada. Ideas, suggestions or jokes would be greatly appreciated. Thanks, Dave
should have looked) so i just drilled a couple small (cant recall the size, probably about the size of a pens ballpoint, if that helps) holes, and put the t-stat in with them a 12o'clock... ran fine.
