thermostat install question
Knuckles4696
now i installed my new thermostat, it had a bunch of red gunk on it rtv i think it is as a gasket which i peeled all off and ran it metal to metal. Now its leaking i feel dumb asking but was i supposed to put something between the block and the thermostat housing? if so recomendations on what i should use? on a positive note after doing an almost full top end rebuild it started on the first try minus the whole leaking of some coolant. Thanks for any advice.
zblackbeast
SHOtarded
Omaha, NE
Yeah. You need a gasket. They're usually only a few bux at the parts store.. rtv really isn't needed, but its extra insurance if need be.
Knuckles4696
so is there an actual gasket? cause i bought the seal, but i could find an actual gasket that sits around the area were yu put the bolts in.
zblackbeast
SHOtarded
Omaha, NE
Seal/gasket whatever.. look on shosource and you'll see. If advance or azone doesn't have it, try rock auto, rcmautomotive or shosource.
AREA 91
PA SHO SHOP
Area 91
There is a round gasket/O ring that goes around the outer diameter of the thermostat itself.
I recomend a little RTV around the perimeter of the thermostat ****** itself.
Do not over torque the nuts or you may break the little studs.
