thermostat help asap
kickeralpine
ohio
i just did a 60k and car was sitting for about a year and a half. got it all put back togher and when the temp gauge went up it came down when stat opened then the gauge never went up again and today i started the car and in about 3 minites of running the heater had warm air already is the stat stuck open or do i have a head gasket blow also when i took off the cap last night before the stat opened it had all kinds of pressure now when it opened it dont so i think the stat is stuck open am i right or is somthing else wrong it is an 1994 3.2 axt
SHOoff89
Anchorage AK
If you have not changed the thermostat, do that first. It's cheap and might just fix your issue.
kickeralpine
ohio
no didnt do that yet but what i did notiice was last night before the stat opened i coudnt take the cap off because it had pressure then when the stat opened i filled it full and after that no pressure replaced cap still no pressure so i think the stat is open but for it open has great heat but it was 60 today so i think thats why and i have no leaks at all so you guys think its the stat and gauge doesnt move ether did last night till the stat opened
SHOtimer
#2910
Santa Clarita, Ca
You need to begin by replacing that thermostat along with the temp gauge sender. The sender is (when looking at the thermostat) to the left of it, it has one wire coming off of it and will cost you just a few bucks to replace. Replace both of those, and refill with new coolant, get all the air out,then lets go from there.
Doug
kickeralpine
ohio
one other question is its like 20 degrees today and in about 12minites of running at an idle it was getting good heat is this normal for it to heat up that quick
Shoaz
Studly dood
Scottsdale, AZ
The job of the thermostat is to allow it to heat up quickly, so I think your thermostat is probably working fine. I'd think twelve minutes at idle would be sufficient to warm it up. Doesn't sound like anything problematic to me.
kickeralpine
ohio
thanks for the help but i still anit getting pressure heat is good i have no bubbles in rad and no leaks at all it had pressure till the stat opened that first time when i got it running
kickeralpine
ohio
i did but still no pressure its from auto zone same thing happened on my cav got cap still no pressure got anoughter cap worked fine but didnt have problem with pressure till the stat opened
Ishodu
If you can't get any pressure and your cap is in good shape. You prolly have a leak.
The sensor on the heater line is for the auto climate control. When on Auto it will wait until it gets to a certian temp before the blower will increase speed to warm the cabin.
SHOtimer
#2910
Santa Clarita, Ca
I was searching for something else and came upon this post by SHO NUT speaking about the cooling system. Basically, he explains that without a thermostat the SHO will overheat...
Careful guys, the SHO cooling system is unlike anything seen in most domestic engines. It uses a full flow recirculation system (that's what the coolant tube is used for on the top of the engine) to recirculate all the coolant around the rad when it's not being used, as opposed to the t-stat just shutting the coolant flow off like most other engines do. That's why a 'normal' thermostat won't work in an SHO. The SHO thermostat is actually a 3-way diverter valve, as opposed to an on/off valve, either directing the flow through the tube, through the rad, or a combination of both, depending on the engine's cooling needs, all the while maintaining a full coolant flow through the block/heads (a good idea). If the diverter section (the disc on the back end of the t-stat) isn't part of the thermostat, then the water flow will go though the tube instead of the rad (just like if you remove the t-stat), and the engine will overheat, regardless of whether or not the t-stat is open or closed.
Just a bit of insight for you. You need to first put the thermostat back in.
Doug
kickeralpine
ohio
hay that was cool of you to post that and i thank you this would explain why the sho heats up faster then most cars do. i now mine warms up quick i tought it might be a head gasket. but after reading your post that looks like the stat is probly open and wont build pressure. because it did till it opened plus the car sat for a long time i just want to thank all of you for your help thanks so much im learning alot about my sho here
SHOoff89
Anchorage AK
Wow, I swear I learn something new every time I come on the forum.
Thanks Shotimer and Shonut!!! :thumb:
kickeralpine
ohio
ok i did the cap still no pressure no leaks i got gauge from autozone held pressure also when it was warm here i had good heat now its 25 and luke warm heat does it sound like the stat is open it ran for 45mins and only got warm didnt defrot windshield
kickeralpine
ohio
found the problem tonight pulled the stat out was stuck open going to ford monday thanks guys
