Hey guys, I need help with a plan of attack.
List of current issues with the new SHO.
1. Door switch is either failed or stuck
2. Driver door lock cylinder damaged
3. Wiggle of the back of that lock cylinder causes locks to operate. Don't know if the lock cylinder damage relates
4. Only have one key and that key does not open trunk. Did 98 have a separate trunk key or is that lock cylinder failed.
5. Despite door switch issues, no light on dash "AJAR" Did somebody pull a fuse?
6. Forward doom lights been removed most likely due to door switch.
The problem is somebody made attempt to break into the vehicle. The driver door handle has been bent up, and I suspect they probably took a screw driver to the lock cylinder which is why its broke, and the key doesn't work.
With all the current issues kinda being related to each other I really don't have the best plan of attack on this one, because I am chasing multiple issues.
Should I just contact ford for a replacement lock cylinder that will fit my key, replace electric connector on that lock cylinder and perhaps purchase a door switch?
Should the ignition key operate the trunk lock cylinder? If so I guess I need to order that one as well.
I would really like to get this issues correct and ideas or suggestions would be great.
Thanks!
Just seems like I should replace most of the parts, hook it all up and go from there?
Thanks!
